ESP-8266 DIN rail power monitor
ESP-8266 DIN rail power monitor with external current transformers.
Public Chat
It is an ESP-8266 DIN rail power monitor with external current transformers. The transformers allow to monitor, in a non-invasive way, the power absorbed by the line and the energy introduced by generators such as wind or photovoltaic. The main use is to maximize autonomous energy consumption using IoT home automation software.
In my realization I use Domoticz as a home automation center for IoT and ESPEasy for the detector. Equipped with a display for local reporting, it has two 0/1V analog inputs to connect current transformers. The inputs are passed through two weighted peak detection circuits, and then sent to two 16bit ADCs.
rules_consumi_watt.txt
Rule consumi adopted to send dato to controller
plain - 391.00 bytes - 08/26/2021 at 15:14
Download
octet-stream - 1007.41 kB - 08/26/2021 at 15:14
Download
rules_fotovoltaico_watt.txt
Rule generation adopted to send dato to controller
plain - 799.00 bytes - 08/26/2021 at 15:14
Download
Adobe Portable Document Format - 650.32 kB - 08/26/2021 at 15:12
Preview
Download
Datasheet-HLK-PM01.pdf
Switching Data
Adobe Portable Document Format - 427.45 kB - 08/26/2021 at 15:12
Preview
Download
View all 10 files
