Product Specifications
General
Type: DC to DC Automatic Boost Buck Converter (non-isolated synchronous rectification)
Architecture: For all electronics
Installation Method: With 4 pieces of 3mm screws
Operating Temperature: - 40°C ~ 85°C
Operating Frequency: 150 KHz
Conversion Efficiency: 96% (maximum)
Module Protection: Over current (with 10A fuse), short circuit and over-temperature protection (output voltage will decrease if over temperature)
Note: There is no input transposition protection, however, if necessary, you can connect a diode on the module's input port.
Power
Input Voltage: +5 - +32 volts
Input Current: 8A (maximum)
Constant Current: <= 6A
Quiescent Operating Current: 3mA
Output Voltage: +1.25 - +20 volts
Output Current: 5A (maximum)
Weight and Size Dimensions
Product Weight: 40g
Product Size (L x W x H): 6 x 4 x 3 cm
Product Review
Since this module has multiple uses in the electronic field, this boost buck converter accompanies a lot of decent factors which include:
1. Its high efficiency within its output voltage range, around 90% or more so that it can maintain its power while being stepped up or down.
2. The module's various amounts of protection, so that the components on-board, the load and you, will be safe from any live electricity.
3. Its wide voltage ranges, which can be used for most of your hobby electronics, and the module's ability to handle 8 amps of high current.
4. The 4 mounting holes on this converter to hook it up on any surface and its overall compact size.
5. The fact that there is a heatsink located at the bottom of this converter for heat dissipation so this converter doesn't get hot when working with large
amounts of power.
Product Tour
ICStation Product Page
PictureCheck out the product here: http://www.icstation.com/product_info.php?aid=294&products_id=11058
For purchases from ICStation, use this code for a discount:
Code: Simics
Discount Amount: 15% off
Max. Use: 1 (one per user)
Amount Limit: 300
Amazing opportunities
Also, be sure to check out PCBWay, a leading manufacturer and distributor in PCB design and manufacturing. They have amazing prices and excellent quality in their services, so don't miss out on them! Plus, PCBWay has an amazing website, online Gerber viewer function and a gift shop so make sure to check out their links below:
PCBWay Free Online Gerber Viewer Function:  https://www.pcbway.com/project/OnlineGerberViewer.html
PCBWay Gift Shop: https://www.pcbway.com/projects/gifts.html
Be sure to check out the DC to DC Automatic Boost Buck Converter 5 - 32V to 1.25 - 20V 5A Setup by clicking here.
Enjoy! Contact us for any inquiries!
