Lightpool
An economic laser array using a single source for innovative light shows
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This project consists of a modular tile based system. Each of the tiles can split a laser at very high speeds into many using a mirror system, thereby allowing for large light installations using parallel lasers at a fraction of the cost, with a resolution of 10x10cm, which can be increased. The mirror system is designed programmatically, and allows for distinct mirror holders to be laser-cut at the appropiate angles, guiding the laser from different orientations into discrete parallel rays. The laser source is guided using a galvanometer scanner, which can scan fast enough for the rays to be simultaneous as percieved by the human eye. A physical prototype might be developed in the future if time (and money) allows.
This was a thesis project for a design engineering degree.
Full report with design dev (basic schematics): https://drive.google.com/file/d/1GvTaFBz1gd5SaJ7zN8u7IJ_E-j7wZuJ0/view?usp=sharing
