It's a low-cost alternative to tens of thousands-of-pound environmental monitoring stations, and it's compact and hackable, allowing you to donate your data to initiatives that monitor air quality.
![](https://cdn.hackaday.io/images/6726771637150961063.png)
With the Pico Sense HAT, Air Quality for Raspberry Pi Pico, you can keep an eye on your surroundings! These boards have a slew of sophisticated environmental sensors, as well as a lovely small full-color LCD to display your data. They're an excellent approach to begin citizen science and environmental monitoring.
Along with the four sensors to assess temperature, air quality, humidity, and colour, the Pico Sense HAT add-ons board for Raspberry Pi is ideal for environmental monitoring. It would be great for the user if we could build a safe atmosphere for the next generation.
What's Raspberry Pi Pico Sense HAT? How Pico Sense HAT can be used!
Raspberry Pi Pico Sense Add-on Board is a great products for developers and makers who want to build wonderful Pico projects that accurately monitor air quality. Pico Sense HAT began as a monitoring device that allowed everyone the developer community a method to preserve the environment using four sensors: temperature, humidity, air quality, and colour. The Raspberry Pi Pico lacks network connectivity, thus a tiny colour LCD display on top is designed to offer local feedback of the data from each of the four sensors.
SB Components, an technology company, has launched a Kickstarter campaign for a Raspberry Pi Pico add-on that includes environmental sensors and a handy on-board display, as well as a free Raspberry Pi Pico to get you started.
"Many individuals may wonder why environmental monitoring is so important? which is a reasonable point, "With the changing environment, the most hazardous challenges for us are global warming, air pollution, water pollution, and so on. We would collect data on air pollution from regular environmental monitoring, which would allow us take appropriate steps."
What you think about Pico Sense HAT?
Posts You May like:
- The New Version of Raspberry Pi OS, Debian "Bullseye" is Now Available.
- The Raspberry Pi Zero 2 W Arrives Six Years After The First Pi Zero
- Raspberry Pi 4 Has Been Given Vulkan 1.1 Compliance by Khronos
- The Raspberry Pi Build HAT - Complete Guide
- Raspberry Pi Officialy Announced Build HAT For Raspberry Pi
- Installing Android on a Raspberry Pi 4 with Google Play Store
- Pop OS Linux is Coming to Raspberry Pi and Other ARM Devices Soon
- How to Immediately Upgrade to Windows 11
- A Secret Update for the Raspberry Pi 4 8GB
- Raspberry Pi Introduces a New Documentation Hub
- Quick start with ESP8266 based Pico WiFi HAT
- Capture local Real-Time Air Quality Data with Raspberry Pi Pico
- GitHub CLI 2.0 Is Now Available, With Extension Support
- Connecting Wi-Fi on Raspberry Pi Pico Become Easy
- How To Track All Devices with Raspberry Pi
- Make your own Raspberry Pi Image from scratch
- How to Send phone notifications Using Raspberry Pi Pico?
- Raspberry Pi Pico 4G/2G Expansion : Expectations vs. Reality
- Quick Example to Drive Servo Using Programmable I/O
- How to Use a USB SSD or Flash Drive to Boot a Raspberry Pi 4 / Pi 400
- Filter Ads by your Raspberry Pi Before they Reach your Devices
- A Raspberry Pi 4 Model A Launch 2022 - Eben Upton
- First-Ever 2G Expansion Board for Raspberry Pi Pico has Launched on Kickstarter
- Learn IoT "Internet of Things" with 24 lessons for Teachers and Students
- Quick Guide for Raspberry Pi Users: Raspberry Pi Terminal Commands
- Windows 11 on Raspberry Pi Devices in Easy Installation Guide
- Get Your Project Done by Raspberry Pi Approved Design Partners
- PiRelay 8 Smart Relay Board for Raspberry Pi - Kickstarter
- Tiny Round/Circular LCD Display Launched!
- Issue Fixed! USB Boot Ubuntu Server 20.04 on Raspberry Pi 4
- HC-SR04 Sensor with micro-ROS on the Raspberry Pi Pico
- Raspberry Pi Pico: ADC Sampling and FFT
- Using CircuitPython for RP2040
- How to Setup Pico RP2040 on Windows
- Using micro-ROS on the Raspberry Pi Pico
- LED Tricks Using The Raspberry Pi Pico
- The RP2040 Raspberry Pi Pico Meets LoRa
- Pico supports SD cards and FatFS
- How to connect a Raspberry Pi Pico to LoRaWAN
- 50 Raspberry Pi Hacks & Tips You Should Know
- How to Install Wi-Fi and Internet on a Raspberry Pi Pico
