CAN DAB HAT
JLCPCB Sponsored CAN DAB HAT PCB Project with Penn Electric Racing
The CAN DAB Hat Board is a board that will be used to test and check the functionality of CAN Data that will be transmitted to the Raspberry Pi. We use 4 different headers for 4 different CAN buses used in the car which then will go through a CAN transceiver and a CAN FD controller with SPI interface. This controller will then send SPI data to a GPIO Header for a Raspberry Pi.
The key components in this board are the MCP2561/2FD and the 40 Pin GPIO Header which will be used to interface with a Raspberry PI 4 to test whether CAN Data can be sent to a Pi properly.
The MCP2561/2FD is a cost-effective and small-footprint CAN FD controller that can be added to a microcontroller with an available SPI interface.
It has the following features:
  • VIO Supply Pin to Interface Directly to CAN Controllers and Microcontrollers with 1.8V to 5.5V I/O
  • Power-on Reset and Voltage Brown-Out Protection on VDD Pin
  • Protection Against High-Voltage Transients in Automotive Environments
  •  Very Low Standby Current (5 µA, typical)
  • High ESD Protection on CANH and CANL
The Raspberry Pi 4 is a credit card-sized computer system and comes with a high-performance ARM Cortex A72 4x 1.5 GHz quad core processor.
  • Quad core 64-bit ARM-Cortex A72 running at 1.5GHz
  • 1x SD Card
  • 2x micro-HDMI ports supporting dual displays up to 4Kp60 resolution
  • 2x USB2 ports
  • 2x USB3 ports
  • 28x user GPIO supporting various interface options:
  • High operating range of 0 to 50 degrees Celcius
CAN Test Hat.pdf
CAN Test Hat Schematic
Adobe Portable Document Format - 1.53 MB - 12/16/2021 at 01:38
Preview
Download
_DAB CAN TEST HAT BOM.xlsx
Bill of Materials for JLCPCB Assembly
sheet - 7.83 kB - 12/09/2021 at 16:25
Download
Instructions on Ordering PCBs from Altium.pdf
How to Export Altium ZIP File for JLCPCB Manufacturing and Assembly
Adobe Portable Document Format - 314.46 kB - 12/09/2021 at 16:23
Preview
Download
  • 1
    Ordering the PCBs
    Now, with our PCB design in hand, it's time to order the PCBs and Assembly. For this step, head to JLCPCB.com, and click on QUOTE NOW.
    JLCPCB has sponsored our project. JLCPCB (ShenzhenJLC Electronics Co., Ltd.), is the world's largest PCB prototype company and the leading high-tech manufacturer specializing in quick PCB prototypes and small volume PCB production. You can order PCB and SMT Assembly starting at just $2 for 5 PCBs. You can read more about them on our website here: https://www.pennelectricracing.com/s/JLCPCB-Sponsorship-Document.docx
  • 2
    Add Your Gerber File
    After exporting your gerber and drill files from Altium (see Files section for instructions), compress them and upload your zip file to JLC's website.
  • 3
    Confirm Options
    Here, you can see we successfully uploaded our zip file. We are then able to review our board using the Gerber Viewer function to ensure that both the Top and Bottom layers look good.
View all 4 instructions
