Design
I took the armorer helmets as template and get the drawings done on inkscape
The black color is the Front solder mask aperture , it means that metal will be exposed.
To achieve the golden beskar steel looking i choose the ENIG pcb finish.
*I don't own any right on characters , it's a fan made gadget .
Electronics
•Operation Voltage 1.8V – 3.6V
•Up to 512 Words of Flash Program Memory
Printed circuit board
Kicad have a huge comunity and plugins , one of them it's svg2shenzen by badgeek , an Inkscape extension for exporting drawings into a KiCad PCB.
Manufacturing PCB
I've been ordering my boards from JLCPCB , have a fair price and great finish. The process was easy and fast, dropping GERBER files , selecting ENIG finish, thickness and quantity. It took one week to get my boards back. I'm happy with the service.
Function
The LEDs are controlled by charlieplexing technique ,so 1 LED is running at time,this POV feature save power and works great with low pin count mcu.
Pressing the button will change the LEDs animation until go to sleep again.
Aesthetics
- Be proud to wear this badge.
- The PCB have ENIG finish , golden color match.
- White silkscreen on black soldermask
- Small size, 30 x 35mm
- The lighting will do a great effect on cloth.
Assembly
Forge your helmet
- Six white LEDs / 0805 package size.
- One microcontroller sot23-6 package , show your skills.
- One push button 3x4mm
- One cr2032 Battery holder
- One Pin
- One capacitor 0805 package size
- Be ready for the diy soldering kit .
- THIS IS THE WAY -
The good looking of beskar
