Working fast
A project log for 2022 HDP 3 - Hack it Back
Repurposing of an old fan to promote a healthier life and work environment
giovanniGiovanni 05/04/2022 at 00:430 Comments
From the very beginning, the concept revolved around having as much air available for the CO2 sensor to do its job. The first iterations for the node had a towered design with a steel mesh covering almost 360 degrees. I liked this design, but it proved to be a bit difficult for construction. The meshes were either too rigid to bend to a cylindrical shape, or too flimsy to keep that shape.
Additionally, these units would be too fragile, and even a slight bump may damage, dent or even break them. So it was time to move to a single body shape.
PCB design was already underway so we had three main components for the nodes:
- the main board,
- an independent pcb for the CO2 sensor,
- a second independent PCB for the air quality sensor.
