[M] Motor Pad
A project log for Tetrinsic [gd0041]
A continuous, motorised fader that is force sensitive and haptic.
kelvinakelvinA 10/09/2022 at 21:540 Comments
It's not much but it's still honest work. I've also moved the capacitors closer to the MP6543 and I've tried to make the pads somewhat large because I suspect that I'd have to actually solder some small wire.
I modelled the cable of the motor from the AliExpress images and I don't think it's going to be long enough to make it all the way over. Even if it was, it doesn't seem like the easiest of things to solder since there is insulation covering the top of the pins.
Next thing to do is either make more pads for other connectors, double check the schematics to finally confirm if I'm using a 5 pin ribbon cable or something else or start learning how the M032 MCU is programmed. I could do the last option whilst waiting for the PCB and parts to arrive, so it's likely going to be one of the first two options.
