[T] Cutting the load cell
A project log for Tetrinsic [gd0041]
A continuous, motorised fader that is force sensitive and haptic.
kelvinakelvinA 02/14/2023 at 10:030 Comments
To reduce size and complexity while increasing encoder accuracy, I'm going to cut the load cell so that I can obtain the above solution. The 4.55mm gap is where the PCB will go. I'll be using an 8mm x 1mm diametric magnet.
