Chattering relays and counters
A project log for Another Geiger Counter
Geiger counter under glass dome using electro-mechanical pulse counter.
daw9000daw9000 03/04/2022 at 01:290 Comments
I initially had big problems firing the pulse counter. I used a 5v relay to pulse 12v to the counter but kept getting relay chatter even when using driver circuits. Eventually I placed a high speed schottky diode across the counter terminals which solved the issue. Pulse length was another critical part of stopping the chatter and reliability.
