Example Project 1 - Rundumleuchte
A project log for The Atmega Hearth
Lets imagine a cheap core for all your breadboard µC Projects.
stefan-xpStefan-Xp 07/10/2014 at 21:430 Comments
This is a easy 8 Output one Input + I2C Project. It is part of a bigger project ;-)
What does it do?
http://www.liveleak.com/view?i=0cd_1295609192
It lights up with different patterns of blue light :-)
In this case i used a coper plated FR4 board. I just drew the traces with a marker, so this is quick and dirty.
On the plus side: Later on nobody will notice it :)
For this Project I ordered a few super bright blue 3000mCd LEDs. Those THT types had suprisingly the most convenient brightness / price ratio.
As you can see i placed the Atmega Hearth in the center and connected it to the board.
Then added the LEDs + Resistors and a Push-Button. I really like the Marquardt 3006 Series :-) (y)
The push button is used to switch modes manually. The modes are also changeable by I2C command.
Please take a look at the pictures and note, that it is not yet finished :)
This is the Top Side:
This is the Bottom Side.
This is how it looks like in action
