monitor type program embedded into option rom of ne2000 compatible card working on XT class computers
I've realized that real NE1000/2000 cards had 2764 as option rom which is 8kB.
I've resized firmware and I barely fit into new constrain.
I use https://www.tindie.com/products/weird/isa-8-bit-ethernet-controller/ as real hardware and it allows 16kB roms which I've initially targeted.
BTW I've added broadcast packet with mac sent when boortom wakes up after geting IP from DHCP server.
PYTHONPATH=$PWD nbdkit -f --filter=blocksize python nbd.py ip=192.168.1.105
nbd-client 127.0.0.1 10809
$ ddrescue /dev/nbd0 pb8088rescue.raw pb8088rescue.nfo GNU ddrescue 1.26 Press Ctrl-C to interrupt ipos: 42205 kB, non-trimmed: 2336 kB, current rate: 21845 B/s opos: 42205 kB, non-scraped: 0 B, average rate: 17365 B/s non-tried: 12518 kB, bad-sector: 0 B, error rate: 0 B/s rescued: 27364 kB, bad areas: 0, run time: 26m 15s pct rescued: 64.81%, read errors: 59, remaining time: 10m time since last successful read: 0s Copying non-tried blocks... Pass 1 (forwards) ipos: 65536 B, non-trimmed: 3621 kB, current rate: 5006 B/s opos: 65536 B, non-scraped: 0 B, average rate: 15878 B/s non-tried: 6619 kB, bad-sector: 512 B, error rate: 2275 B/s rescued: 31978 kB, bad areas: 1, run time: 33m 34s pct rescued: 75.74%, read errors: 93, remaining time: 18m time since last successful read: 0s Copying non-tried blocks... Pass 2 (backwards) ipos: 196608 B, non-trimmed: 4268 kB, current rate: 0 B/s opos: 196608 B, non-scraped: 0 B, average rate: 15468 B/s non-tried: 3145 kB, bad-sector: 512 B, error rate: 32768 B/s rescued: 34804 kB, bad areas: 1, run time: 37m 30s pct rescued: 82.43%, read errors: 110, remaining time: 9m time since last successful read: 2s Copying non-tried blocks... Pass 4 (backwards) ipos: 14417 kB, non-trimmed: 5460 kB, current rate: 21845 B/s opos: 14417 kB, non-scraped: 0 B, average rate: 14750 B/s non-tried: 0 B, bad-sector: 512 B, error rate: 0 B/s rescued: 36758 kB, bad areas: 1, run time: 41m 32s pct rescued: 87.06%, read errors: 138, remaining time: 6m time since last successful read: 0s Copying non-tried blocks... Pass 5 (forwards) ipos: 26082 kB, non-trimmed: 0 B, current rate: 20480 B/s opos: 26082 kB, non-scraped: 990208 B, average rate: 13730 B/s non-tried: 0 B, bad-sector: 62976 B, error rate: 0 B/s rescued: 41166 kB, bad areas: 123, run time: 49m 57s pct rescued: 97.50%, read errors: 260, remaining time: 54s time since last successful read: 0s Trimming failed blocks... (forwards) ipos: 14658 kB, non-trimmed: 0 B, current rate: 9216 B/s opos: 14658 kB, non-scraped: 0 B, average rate: 8450 B/s non-tried: 0 B, bad-sector: 499712 B, error rate: 0 B/s rescued: 41719 kB, bad areas: 138, run time: 1h 22m 16s pct rescued: 98.81%, read errors: 1113, remaining time: 0s time since last successful read: n/a Scraping failed blocks... (forwards) Finished
View all 6 project logs
Lex Kravitz
Kn/vD
Paul Stoffregen
tobias.kornmayer
Yes, delete it Cancel
You are about to report the project "NE2000XT", please tell us the reason.
