100% reusable electronics
No more soldering!
Public Chat
Suppose I give you a battery a resistor and an LED.
Can you not simply by holding the parts in your hand make the LED light up?
All you need is for things to make contact so electrons flow and it will work. Is that not so?
So why is the electronics industry bent on packaging and soldering things together?
Ah I get it. It is so that the parts don't fall apart and the contact is permanent right?
When parts fail and the circuit stops working the whole thing goes to the dump or ends up in a frying pan in some third world country to recover precious metals.
What if I show you a radically new way of packaging electronics that is 100% reusable.
Imagine entire circuits that are only held together to maintain contact so electrons flow but only temporarily.
No need to solder at all. No toxic fumes. No reflow process.
When one or more part fails simply loosen and replace damaged parts or recover the rest of the parts and reuse them again in other circuits
Images cannot be in the project section so here is a recap so you get the idea:
PS: The country where I live is remote and shipping costs a lot plus it is a small market. I ordered an LED from a local online store. It took 2 weeks to fill the order of 1 LED and 1 resistor and that after I had to call to remind them they had a pending order. The one LED I purchased for Rs 2 did not work! Can you believe it! Bad luck. (: Fortunately my friend from New Zealand bailed me out with the pictures I wanted to show to illustrate the concept above. Thanks Collin.
Have I convinced you yet? Now read on...
Unless you’ve been living under a rock or in a cave in a remote place with no modern form of communications you should be well aware that we have a problem with electronic waste all around the globe.
Just search for e-waste on Youtube or Google and you’ll find grim titles such as:
How e-waste is harming our world
E-waste: Why We Need to Act Now
The explosive problem with recycling old electronics
E-Waste Hell
E-waste: How big of a problem is electronic waste?
I stop at a few but the list goes on and on.
The thing that surprised me watching some videos about the recycling process is that inevitably the first step after some disassembly and the removal of batteries is the grinder!
Everything goes through the grinder and comes out as a fine powder. Then the material recovery process begins.
Nothing is reused as is really.
Gee is that the best we can do? Really?
Imagine the millions if not billions of electronic components that are most likely good to be reused as is that we grind up!
What if we could recover and reuse most of those!
Ahh but it costs too much to desolder to recover them you are thinking.
Just crush it all up and we'll see what metals, plastics and fiber we can recover from that.
That’s good enough. Who cares anyway. That's a messy business with a small margin anyway.
What if I told you we can do better!
How is that ? Said by the naysayers.
I hear you. Every new idea is often met with resistance and ridicule in the beginning.
In putting up my idea for this competition I might be subject to a lot of criticism but I am taking that risk.
Some may think I have fallen off my rocker!
I ran the idea through a few veteran electronics freaks I know and they thought:
That’s thinking out of the box - Collin Pillay.
That could be useful, do put the idea out there - Deon Smit.
I’ll spare you the morality speech as to why we should at least try to reuse and recycle at some level and introduce you to my lunatic idea.
Fundamentally it goes like this:
Suppose we did not solder electronic components on printed circuit boards at all.
Imagine how many good things could come of this.
For starters we can easily get to the components to repair, recover and reuse.
sch - 942.76 kB - 06/11/2022 at 12:17
Download
brd - 65.95 kB - 06/11/2022 at 12:17
Download
sch - 941.64 kB - 06/11/2022 at 12:16
Download
brd - 64.79 kB - 06/11/2022 at 12:16
Download
epf - 11.77 kB - 06/11/2022 at 12:16
Download
View all 20 files
  • 1 × This idea applies to any electronics component As long as it has pins that can be pressed against solder pads to make an electrical connection it is good to go.
  • Connectors
    Alain d'Espaignet06/11/2022 at 13:33 0 comments
    What about connectors you say.
    Well for SMD ones I do not see an issue.
    For THP connectors and or components I know from experience that you can make the drill holes tight enough that you don't need to solder.
    Push the component lead into the tight hole in the PCB and the contact is good to go.
  • Lazy?
    Alain d'Espaignet06/11/2022 at 13:26 0 comments
    On Sparkfun and Adafruit you can find electronics that is open source.
    Typically these sites provide the EAGLE schematic and PCB files for a project.
    I grabbed a few of those and applied the cavity process to them.
    What I found is that the original design did not have 3D models assigned so going 3D to Fusion 360 produced no 3D PCB.
    It means I'd have to make realistic 3D models for those and also their cavity variants.
    Over time one would build a library for those and the process thereafter is fairly simple.
    I simply ran out of time to do this to showcase the process before the competition cut off date.
    But that is something that I am interested in exploring because I think hobbyists may be keen adopters of the approach.
  • Challenges
    Alain d'Espaignet06/11/2022 at 12:54 0 comments
    Evidently as with every new idea comes unexpected twits and challenges.
    Cavity plate material
    The first time I tried this process I picket the wrong material for the cavity plate.
    So far I have presented the idea in the next phase of this project, the implementation phase I anticipate spending a lot of time finding the right material to use to make cavity molds.
    3D printing
    If I go with 3D printing I'll be limited with the materials usable with this technology.
    The  good news is that I know someone who has access to a 3D printer at work and he is keen to try this technique out too.
    In the country I live the government encourages 3D printing and provides facilities free of charge. I'll be checking this service for sure.
    I don't have direct experience with 3D printing yet and I am skeptical that I will be able to create rigid boundaries between cavities.
    I have seen some 3D printed objects and was not impressed with the overall quality.
    Electronic components dimensions have tolerances. Some parts may fit snugly in cavities others of the same package type might be too loose. In designing the cavity the right tolerance and material stiffness has to be found so that I don't end up with parts rattling inside.
    Someone brought up the issue of heat and deformation or even melting of 3D printing materials. This remains to be seen.
    CNC milling
    I had a Sherline 2000 + many mods before so I know what it is capable of. I'll fall back to CNC milling if 3D printing does not work out.
    Contact pressure
    There is a possibility that the contact pressure of the cavity plate is not sufficient to make all contacts reliable.
    The mitigation plan for this is glue and or fasteners. Small screws that will squeeze it against the PCB.
    I am not so keen on glue because of defeats the purpose of having easy access to the parts but it has value. See next.
    Corrosion
    The PCB traces may suffer from oxidation from being exposed to the elements especially if I omit the solder mask process in the PCB manufacture. That's why I am thinking it may be a good idea to glue down the cavity plate for it will seal the components in place.
    Another idea is to put the whole thing in a recyclable vacuum bag and seal the whole thing. Like shrink wrapping.
    Adoption
    The next hurdle is getting folks to adopt this packaging method. Does the benefits outweigh the added process and cost? That remains to be seen. Imagine if all the circuits you can buy from hobbyist online stores like Sparkfun or Adafruit provided a cavity plate alternative purchasing option would you go for it? Anyhow here I am speaking about the electronics hobbyist market, there may be a reuse interest there however to maximize the impact on the planet it would be best that the technique is adopted in consumer electronics.
    Imagine your run of the mill TV remote control unit being made this way. When it fails maybe you could sell it back to a shop that can open it up and resell the components.
    The PCB industry has advanced and streamlines its process and here I come along with a disruption.
    What no solder mask?
    What no reflow?
    And now you also want our pick and place machines to pick up parts upside down and drop them inside little cavities in a plate.
    I can see a lot of resistance there. Can existing tooling do this? Can glue dot placing machines drop glue dots inside small cavities?
    Scaling
    Yet another hurdle is the scaling aspect. It is not far fetched to think that one a cavity plate is designed for a product it can be stepped and repeated to make a mold that will mass produce them. Its like making a mold for a mold.
    These are a few of the issues that I'll be faced with next.
  • TLDR
    Alain d'Espaignet06/11/2022 at 11:31 0 comments
    If you are impatient: tldr here is the end result:
  • Definition of terms
    Alain d'Espaignet06/11/2022 at 11:30 0 comments
    Cavity plate
    The parts of an electronic product that serve to keep the components in place and force their terminals to make contact against a printed circuit board.
    Cavity plates can be 3D printed or CNC milled.
    A mold of a cavity plate stepped and repeated can be made to produce them in large quantities.
    They should be made of recyclable materials.
    Cavities
    The holes in the cavity plate that adapt to the shape of components to keep them in place.
    They may have glue dots placed at their bottom before inserting the components upside down so they don't fall all over the place.
    They can be 3D printed as part of the plate or CNC milled.
    Cavity plate assembly
    Components are placed in the cavities in a cavity plate. This assembly is then mounted and pressed against a printed circuit board. The cavities are designed to adapt to the variations of the component dimension variations and just deep enough to create a force that presses the component pins against the printed circuit board pads.
    Cavity retainers
    These are conical shaped pins that protrude from a cavity plate.
    The pins fit in holes in the printed circuit board tightly as they are pushed in.
    The pins can be augmented with the use of small screws to provide the contact force when assembled.
  • The devil's advocates
    Alain d'Espaignet06/11/2022 at 11:29 0 comments
    Why do we solder anyway?
    Devils advocate (you)
    Lunatic (me)
    To hold things in place, duh, silly!
    We could glue them in place with a light glue that comes off easily.
    To make an electrical connection.
    Spring boards
    bread boards
    wire wrap
    all the methods of making an electrical connection rely on contact between metals and they work.
    Is contact not good enough?
    Look around you how many things rely purely on contact.
    Every switch, wall plug, light bulb, relay, contactor…
    All these make contact and electrons flow, don't they?
    To package things in a box and make it pretty.
    What if the box itself helps keep the parts in place?
    To reduce contact resistance.
    What's the order of magnitude of contact resistance in low voltage/current circuits anyway? Milliohms, micro ohms?
    Does it matter a bunch of small resistance in series?
    Is this not working?
    Because that's the way we've always done it.
    Ahh I see.
    Is there anything else YOU want to add to the no can do list?
    Go on, do it!
    What if I were to say, the hell with soldering at all. Lets not solder!
    Make the product packaging itself responsible for holding the parts in place and making them make contact.
    When the product is broken chances are it's just a few parts gone bad.
    In that situation just open it up and get to the individual parts easily.
    Test them until the faulty ones are found.
    Replace them and get the product working again.
    If the product has gone obsolete.
    Open it up. Shake it and all the parts fall in a tray.
    Reuse the parts.
    Oh boy now I really opened a can of worms now!
    The folks in the EU will like to hear this with their ongoing “planned obsolescence” battles.
    The best they managed to do so far is to ask manufacturers to label their products with a repairability rating.
    Let the customer decide which to buy.
    In my lunatic approach to electronics packaging everything is recoverable and everything can be replaced.
    So does that mean it gets a 10/10 rating?
    Come on what is your revolutionary idea luni Alain? Spill it out already!
    Here it goes in brief:
    The key idea
    What if electronics could be built in a way where the housing or sub-housings inside holds the components in place forcing their leads to make contact with a traditional printed circuit board. The housing can consist of one or more modular subunits. Open these subunits and loosen the parts for reuse or repair. This opens up new markets for the easier repair and resale of used electronic parts.
    We don't want just the metal powder left after the fumes have dispersed.
    We want to reuse the bits and pieces! The more the merrier.
    From now on I will elaborate on the general idea.
View all 6 project logs
  • 1
    A simple circuit
    To illustrate the concept I picked a simple LED flasher circuit based on the well known 555 timer integrated circuit.
    I choose an LED flasher because when I do implement the idea I have a quick and visual way of telling if it is working.
    Hey it either flashes or does not! It's a binary decision and as basic as it gets.
  • 3
    Theory
    If you are interested in the theory of operation behind this circuit refer to the article link above.
    For example you might want to use the design equations provided to make the LED flash at different rates.
    The good news is with the 3D cavity plate packaging idea being presented here you can easily swap part values and see the effect immediately, no desoldering, re-soldering required!
View all 28 instructions
