E-book with Ameba (AMB23)
Making an E-book with AMB23 and 7.5-inch E-paper Display Module
Public Chat
Ever thought of making your own E-Book? I would like to develop an E-book using AMB23 as AMB23 has an onboard micro SD card reader that we can make use of to read the contents in a SD card. Many E-book functions will also be implemented in this project!
Getting started with Ameba E-Book Project
The goal of this project is to build an E-book with AMB23.
1. Contents will be written into a text file and save in a SD Card.
2. The content in the text file will be read and display on to the E-paper display.
3. The contents will be split into pages based on the height and width of the E-paper display dimension.
4. Changing of pages can be done by pressing a button.
My plan is to add in the following functions to this project:
1. Long Text Wrap
2. User to be able to choose the orientation
3. Drawing of shapes
4. Add in page number as user flip the pages using button
5. Flip pages using button
The text in the text file is read from an SD card using the onboard micro SD card reader. A long text wrap function is implemented to change the line whenever the sentence approaches the limit of the E-paper width or height without a word being split. A shape drawing function is also implemented to allow users to draw shapes such as rectangle, circle, lines, etc.
7in5_Ebook.ino
Sketch for ebook
ino - 9.52 kB - 07/18/2022 at 01:11
Download
cpp - 64.91 kB - 07/18/2022 at 01:11
Download
cpp - 96.79 kB - 07/18/2022 at 01:11
Download
cpp - 50.16 kB - 07/18/2022 at 01:11
Download
h - 2.71 kB - 07/18/2022 at 01:11
Download
View all 11 files
  • 1 × AMD23
  • 1 × Button
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1 × SD card
  • 1 × Waveshare 7.5-inch E-Ink display HAT
  • E-book with Ameba (AMB23) Update #3
    pammyleong07/18/2022 at 01:15 1 comment
    Updates:
    - e-Book is able to read longer/infinite content. Removed the limit to be displayed onto the EPD.
    - 2 orientations supported: Portrait and landscape
    Wiring diagram provided:
  • E-book with Ameba (AMB23) Update #2
    pammyleong07/04/2022 at 03:04 1 comment
    Added a simple cover page for E-book.
    Cover Page for EPD
    Added button to change pages and text wrap
    Long text are split into many pages and pages can be changed using a button. Page numbers are also added at the bottom right hand corner. The texts are being wrapped according to the size of the E-paper display so that sentence or word will not be cut off. Users can choose and set their preferred font size in the ino. file. Font Size choices: 16, 20, 24. Orientation of the E-book can also be chosen by the user. Orientation choices: 0o, 90o, 180o, 270. When the last page is reached, it will return to page 1 after the button is pressed again.
    Display text with font size 16
    Display text with font size 20
    Display text with font size 24
  • E-book with Ameba (AMB23) Update #1
    pammyleong06/29/2022 at 06:41 0 comments
    28/06/2022
    Functions implemented:
    • Capable to read contents from SD card and display
    • Long Text Wrap
    • Drawing of Shapes
    • User able to choose their preferred orientation of the EPD by modifying the ino file
    • Flip pages using button
View all 3 project logs
  • 1
    Arduino IDE Ameba Board installation
    Add the following line to "Additional Board Manager URLs" under "Preference",
    https://github.com/ambiot/ambd_arduino/raw/master/Arduino_package/package_realtek.com_amebad_index.json
    Next, go to “Tools” -> “Board” -> “Boards Manager” to install AmebaD package.
    Find “Realtek Ameba Boards (32-bits ARM Cortex-M33 @200MHz)” in the list, click “Install”, then the Arduino IDE starts to download required files for AmebaD.
    get-start-8
  • 2
    Connection between AMB23 and E-paper Display
    Take a look at the pin diagram for AMB23
    get-start-3and connect accordingly.
    Busy - D21
    Reset - D20
    DC - D19
    CS - D12
    CLK - D11
    DIN - D9
    The pin numbers definition can be found in epdif.h .
    #define RST_PIN         20
    #define DC_PIN          19
    #define CS_PIN          12
    #define BUSY_PIN        21
    Do note that Display Config should be set to B and Interface Config should be set to 0.
  • 3
    Connection between button and AMB23
    Button pin is defined to be D2.
    Button setting can be found in ino file.
    int button = 2;
    int buttonState = 1;
View all 6 instructions
traceyhoward65 wrote 09/23/2022 at 10:53 point
Really cool idea. When I was at university, I had a guy in my group who had an idea to pull this off. But he didn't make it. I studied at the university of pennsylvania, use https://studymoose.com/university/university-of-pennsylvania to learn more. The university really allows you to create something unique. There is everything for this condition, there would be only a desire.
