A completely encircled thrust structure is required to contain the ashes. It might even force the ashes to the back. There's a strange flow of air currents.
![](https://cdn.hackaday.io/images/1215401666808366612.jpg)
The curved incense sticks have to be put in sideways to catch the ashes. Sticks which are too thin to stand up have to be doubled with a toothpick or wire.
![](https://cdn.hackaday.io/images/9738161666811319247.jpg)
Light the incense by 1st fully assembling it, then using the manipulator to angle it outside. Light it & use the manipulator to angle it inside before it drops ash everywhere. Many a lion has accidentally left it outside after lighting it, leaving a pile of ashes outside the starship.
