Macro samples are usually to large to view on a slide or dish, which means you have to attach them to another object and then lower them into the focal space. The average size of samples that I will be viewing are around .3 to 3mm in size so I decided to design a magnetic sample holder that can be changed easily when changing samples . The sample will be attached to this with a small application of superglue, the amount of super glue necessary for this is smaller than the tip of a needle. The design on the right will be glued into place and the design on the left will be removable creating a magnetic hold. All of these parts are being printed on a resin printer to get the accuracy on the tip.
![](https://cdn.hackaday.io/images/8422711659281519667.jpg)
The magnets I will be using are 1*2mm
![](https://cdn.hackaday.io/images/9001181659281674768.jpg)
Solid view of the stack
![](https://cdn.hackaday.io/images/2818621659281912908.jpg)
X-ray view to show how the magnets will be aligned up.
![](https://cdn.hackaday.io/images/736121659281950619.jpg)
The tips height was important to bring the sample into a position that would maximize light exposure. I was able to simulate this in Tinkercad.
Now I just need to get it all printed and the magnets should be here in a few days.
