DSO138 Case and Battery
In this project we design a case for the DSO138 oscilloscope and make it battery powered
Public Chat
This is the first the first 3D design I developed for 3D printing, it turned out to be quite tricky since the PCB requires many irregular shapes to be able to fit and cover the components but it was a great learning experience.
Front.f3d
Front cover for the DSO138
fusion - 4.72 MB - 08/07/2022 at 10:25
Download
Back.f3d
Back cover for the DSO138, battery and switch
fusion - 3.46 MB - 08/07/2022 at 10:25
Download
Batt_cover.f3d
Small plate to cover 9V battery
fusion - 62.54 kB - 08/07/2022 at 10:25
Download
View all 6 components
  • 1
    Print parts
    Print all 3 provided designs
  • 2
    Wire power
    Place the connector on the 9V battery, solder the ground wire to a pin of the switch and wire the other pin to the negative input of the DSO138 behind the PCB.
    Wire the positive of the battery to the positive of the DSO138.
    Some models come with a plastic connector on the front, desolder this part.
  • 3
    Place the front cover and battery plate and screw it in place.
View all 3 instructions
