Multiplexer pot reading
A project log for Sample based drum machine
lee-sampsonLee Sampson 11/10/2022 at 15:240 Comments
Wanted to test the speed difference between using a multiplexer to read multiple potentiometers from one analog pin vs having them on individual pins.
Code I used. Reads pot 8 times via multiplexer and prints time, then reads pot 8 times the normal way and prints time.
#define number_of_mux 1
#define numOfMuxPins number_of_mux * 8
#define channelA 2
#define channelB 3
#define channelC 4
#define comPin 14
int analogVal[8];
unsigned long timer;
void setup()
  Serial.begin(9600);
  pinMode(channelA, OUTPUT);
  pinMode(channelB, OUTPUT);
  pinMode(channelC, OUTPUT);
  pinMode(comPin, INPUT);
  digitalWrite(channelA, LOW);
  digitalWrite(channelB, LOW);
  digitalWrite(channelC, LOW);
  MuxRead();
  //delay(4000);
  normalRead();
  //delay(4000);
void loop()
void selectChannel(int chnl)
{ //// Select channel of the multiplexer
  int A = bitRead(chnl,0); //Take first bit from binary value of i channel.
  int B = bitRead(chnl,1); //Take second bit from binary value of i channel.
  int C = bitRead(chnl,2); //Take third bit from value of i channel.
  digitalWrite(channelA, A);
  digitalWrite(channelB, B);
  digitalWrite(channelC, C);
void MuxRead()
  timer = micros();
  for(int i = 0; i <  numOfMuxPins; i++)
    selectChannel(i);
    analogVal[i] = analogRead(comPin);
  timer = micros() - timer;
  Serial.print("muxRead = ");
  Serial.println(timer);
  Serial.println("**************************************");
void normalRead()
  timer = micros();
  Serial.print("normalRead = ");
Results (in micros):
muxRead = 141
normalRead = 140
 Multiplexer schematic:
