I wanted to create a low power server that could run 24/7 to self host all my thing. This is my third iteration and i'm happy with it
![](https://cdn.hackaday.io/images/6878461665184873626.jpg)
# Features
* Run ZFS for fast and easy to manage RAID array
* Run docker to host app
* low power (55 Watt max, less idling)
* RockPro64 Powered
* in a nice box to hide the dirty cable (un)management
# Cost
Enclosure : 15$
PSU + RockPro : 120 $
Fans: 10 $
HDD : 0-800 $
PCIe-SATA : 25 $
Total : 170-970 $
# check out github for detailled instruction and more info:
https://github.com/nathmo/makeZFS_armbian
# Harware consideration :
the rockpro64 dont seems to be able to use USB3.0 peripheral on the USB3 Port. but external hdd usually draw more than the 0.7 A that the USB 2.1 can provide so you might need to use a powered USB 2.1 Hub or a USB2.1 extension cable so that you can plug your drive on the USB3 port while forcing the use of USB2.1 for communication.
Also beware of shitty USB stick. I had a TON of problem due to the USB stick dying after 2-3 days/weeks of use even with log2ram.
