Do you commute by bike but are worried about being visible to other vehicles? Keep yourself safe with cycle tail lights! It may seem hard because there are so many options out there, but trust me--you're going to want these one's. Make your bike safe with these quick, easy DIY cycle tail lights! They attach easily to any kind of bike: mountain bikes, road bikes, recumbent bikes--you name it! Check out this tutorial for step-by-step instructions.
After making the circuit diagram I transformed it into a PCB design to produce it, to produce the PCB, I have chosen JLCPCB the best PCB supplier and the cheapest PCB provider to order my circuit. with the reliable platform, all I need to do is some simple steps which we will talk later.
Related Download Files
As you can see in the pictures above the PCB is very well manufactured and I’ve got the same PCB assembled with all the components that we want to use for our main board and all the labels and logos are there to guide me during the soldering steps. You can also download the Gerber file for this circuit from the download link below in case you want to place an order for the same circuit design.
3
Making Custom PVC Designed Body.
Designing and molding body.(Dimensions as per your requirement).
