![](https://cdn.hackaday.io/images/4000771671160056881.jpg)
So I have this large pile (really piles) of wood that I had tucked in a very tiny corner of the shop. This was compact, but annoying. If I ever wanted to get a piece out I had to basically remove all the pieces to have any hope of finding it.
![](https://cdn.hackaday.io/images/430341671158276431.jpg)
Now I have a better plan. I drilled some 3/4" holes into some 24" strips of 2x3 boards. I angled my drill press table about 8 degrees when drilling the holes. Then I mounted these boards to the wall below my new shelves and used various lengths of 3/4" dowels to form temporary shelves to hold the wood.
![](https://cdn.hackaday.io/images/4094731671158351388.jpg)
This is working really great. I have much easier access to the wood and have the ability to sort it by length or type now. In addition I have room to add more 2x3 boards and could easily rearrange things by drilling more holes If needed. I ran out of dowels, so I have not been able to fully organize this, but it was only around $20 to put all of this together and another stick or two should polish it up nicely.
![](https://cdn.hackaday.io/images/3458861671158301364.jpg)
This only takes care of the longer skinnier pieces of wood, I need to come up with another way to deal with the small pieces and larger sheet goods, but it takes care of a lot of the mess.
![](https://cdn.hackaday.io/images/7698991671158909955.jpg)
I do have a problem, I seem to be unable to throw away any wood, no matte how ugly or tiny the piece. At some point I need to go through all of this and make some sacrifices. I'm sure I can cut it in half without much trouble.
![](https://cdn.hackaday.io/images/7880391671159185157.jpg)
This about wraps up the left side of the garage. I may come up with a small bit of something to store a few pieces of sheet goods against the wall, but I like how clean this is. I also will likely put smaller pegs in the lower holes and hang electric cords or other items from them. And there is a bit more room by the bike to extend this system. I may pick up another board and finish that off while I still have things all setup to make these.
As for the small gap on the right side that is between the shelf and wall, I still need to think of something to do with that. I could continue to store wood there that I'm not as interested in accessing. It really is not wide enough to put much of anything else, even a ladder would be difficult to get in and out.
In theory I could move the shelf over and reclaim some of the space by my workbench. Potentially I could move this shelf over 10". It would take the better part of a day to do it, and the shelf would currently interfere with the sensor for my garage door, but I think that could be dealt with. 10" would be useful, but less than that is probably not worth the effort.
