Hero to main - push (termux is installing)
A project log for oiyshTerminal
Local server collection of IoT system with some additional futures. Works by default offline, based on .deb .npm .pipy
yoyoek1yOyOeK1 02/12/2023 at 11:190 Comments
It's time when you need to help me. I need your feed back about: How it's to try it from out site. Is the installation for you went well. Stuff like that. I have to paths:
Those are the manuals how to get otdm-yss running on your setup. yss Is a web interface. Now you will get only test functions page and screens manager to play with your remotes displays. I'm working on releasing more .deb's :slight_smile:
Full description about idea is at main readme.md.
Example: You have android device. You need to have running Node-red on something. You can set up Node-RED running in 1 line. (This command is for Termux) $ curl https://raw.githubusercontent.com/yOyOeK1/oiyshTerminal/main/installer/run2.sh > ./run2.sh; . ./run2.sh And you will have it running no time...
More packages is coming . ..
