An new board is finished, the instruction decoder...or the main part of it. There will be need for a second board with 11 relays to distinguish between the three adress types for Load, Store and mathematical operations.
![](https://cdn.hackaday.io/images/521261679864250413.jpg)
This board will be mounted on top of the instruction register module.
