Monday June 12
A project log for Little Monster
are you ready to meet the scariest mechanical spider that you ever see ?
raphalRaphaƫl 06/12/2023 at 17:260 Comments
After a lot of work, the project is finally put together. As I write these lines, we still have some problems, notably a part which, if it turns too low, destroys the movement. We are therefore adding a small metal piece to block the piece.
Our last problem being the engine which is surely too powerful and will break the gears. The solution to this problem will be found tomorrow. No choice
