Expiration Date App
We are making a project using detection AI which tells the user if something is expired or not using a camera.
We are making a project using detection AI which tells the user if something is expired or not using a camera. For this project were using the Nividia jetson nano as well as other compents that can be found in the compents section, This prototype product is meant for people who can't read or have trouble understanding/proccesing expiration dates. It is intended to be able to be used from people of all ages.
We are making a project in our computer science class that includes 4 people. The project will be an assistive technology device that can help people determine if expiration dates are expired or not. For this project, we are using the Nvidia Jetson Nano, and using it to create the AI.
JPEG Image - 406.29 kB - 04/17/2023 at 17:09
Preview
Download
JPEG Image - 446.61 kB - 04/17/2023 at 17:09
Preview
Download
View all 14 components
  • Week #7 (Final week)
    Max PD06/05/2023 at 17:34 0 comments
    We have finished our project and have presented it to people that use products similar to what we made. They gave us important feedback and we have learned how to improve our project and what we should keep about it. Overall our group as a whole has learned a lot from this project and gained new experiences. Some things we've learned are how to work with and navigate the jetson nano, how to use a breadboard, proper critical thinking skills, and much more.
    Our finished progress:
    By the end of the project we had a prototype that was able to determine if a product was expired or not. It then would indicate to the user by turning a red LED on if the product was expired and a green LED on if the product was not expired. If we were to continue the project we would try making a ai that could detect if a product is expired using a camera.
    Here is our "finished" project:
  • Week #6
    Max PD05/24/2023 at 17:23 0 comments
    We have had our projects graded and we now know what we need to work on. We are going to start improving our code so it is more compatible with different expiration dates. We are also going to try making the LED respond with the code so when we give it a date the led will either blink red or green. Some other people in the group are wokring on preparing for presenting day which is where we are going to talk to people who work with assitive technology and get their feedback on our project.
  • Week #5
    Max PD05/19/2023 at 07:16 0 comments
    This is the last week to create our project and we have made lots of progress however there are still thing left uncompleted. We've finialized our logo design as well as write detailed instructions for our project. As well as that we've included our compents and links to buy them.  Another thing we did was complete our python code however we are unable to confirm if it works or not due to us not completing the AI.
    Link to our python code:
    https://docs.google.com/document/d/1nIVdO9VAY7IjvVSoguJRxsCiUUlNKWlJLmoukRriYXE/edit?usp=sharing
    Images of our prototype:
    Heres some photos of our project working:
    The red light here means that the date that was inputed was expired:
    This is where you input the date and it will tell you if its expired or not:
  • SOURCES
    Max PD05/19/2023 at 06:16 0 comments
  • Week #4
    Max PD05/01/2023 at 17:35 0 comments
    This week we've done a few things to advance our progress in our project. One thing we did was replace our camera because we discovered that our previous camera was not compatible with the Jetson nano. We also now know how to turn on a LED light and decided to move away from making an app and instead focusing on just making one working version for now. We have also developed a python code much more from last week however we are having some trouble making the AI itself.
    We are also making the housing for the LED, the jetson nano, and the camera using this website https://www.festi.info/boxes.py/ and we are also trying to make our own box using and application called sketchup.
    Update 5/4/23: We were told not to use SketchUp and instead moved to using TinkerCad to 3d model our housing box. We also starting review our rubric.
    This is our new camera:
    This is code for the LED to blink:
    On the left side is python code which when given 6 numbers can turn it into a date. For example 06 23 08, the 23rd of june, 2008. On the right side is more code for the LED:
    This is our date converter code using python. When given numbers it outputs a date.
    LED light code:
  • App
    brodiee04/26/2023 at 17:01 0 comments
    We are currently making a app, then we will started making the AI
  • Progress report
    Max PD04/25/2023 at 17:14 0 comments
    Currently, we have a person working on making the ai, one person figuring out how to develop an app, and a person making Python for the app. We just recently started making the app so there isn't much progress on it but we are making more progress on the ai and the Python. We've been downloading open CV on this website to help our program run https://github.com/opencv/opencv.
    This is the website we are using to build our app: https://appinventor.mit.edu/explore/ai2/setup-device-wifi
    Youtube videos we watched to help us learn about ai detection:
    This is our LED light:
    This is some of our python code:
    This is our code for the jetson nano to make the ai:
  • LED ring light
    Max PD04/17/2023 at 17:22 0 comments
    We plugged a LED ring light into the Jetson nano.
  • Programming the Ai
    Max PD04/17/2023 at 17:06 0 comments
    We are currently programming the Ai using Nivida Jetson Nano. To do this we are watching youtube videos and using websites to learn how to use the Jetson Nano. So far we have had a little progress but had a roadblock because we cant seem to replicate what the websites and videos are doing.
View all 9 project logs
  • 1
    Materials
    First gather the materials listed in the compenents section.
  • 2
    Setting up the jetson nano
    Then you will need to connect the Jetson nano to the moniter. To do this plug the connect the hdmi cable, ethernet cable,  and power cable.
  • 3
    Micro SD card
    Insert the micro sd card into the jetson nano.
View all 11 instructions
