WiFi Relay Laptop Charger
Turns on/off if below/above 80% charge
Uses an ESP-01, single channel relay, python with cron. This is for a laptop that doesn't have this built in, and laptop that can't suspend/wake properly.
Floating pins... remember the name, caused me so much headache. Working, I'm using the shared power supply method so I only use 1 plug.
I am using the blue LED as a WiFi connected indicator
RX pin is used later  since it can be set to low on boot.
View project log
