Ṭ̴̯̿̂h̶̫̏̀ę̵̙̒ ̷̩̉C̴̖̞̀͝ọ̵̬̎̔ḓ̵̓e̸̥̞̓̓ part 2 - Pathfinding
A project log for Jumperless
a jumperless (solderless) breadboard
kevin-santo-cappuccioKevin Santo Cappuccio 08/25/2023 at 01:370 Comments
Table of Contents  (bolded ones are in this project log)
Pathfinding
This is the really tricky part. I probably wrote all this code about 4 times, trashed it and started over from scratch with only the lessons learned from the last attempt. Earlier versions would add connections one at a time, but you'd end up in weird states because it has no knowledge of what other paths it needs to make room for. So the final version here clears the connections from the last update, takes in all the connections to be made, and finds paths for the whole board every time you add a new wire. All the old connections usually follow the same paths as last time unless they need to be nudged over to make room for some other path, and the actual connection won't be interrupted at all.
Untitled Here's the schematic of just the crosspoints, the Nano header, and the breadboard.
If you look closely, you'll see that there generally 2 connections (I'm calling these 2 connections Lanes between each breadboard chip, except for the chip that is across from it on the breadboard. And every breadboard chip has one connection to each of the special function chips. The pins on the Nano header has a connection to 2 special function chips (interleaved to make it easier to connect continuous pairs of pins to the breadboard).
Here's the high level outline of what NetsToChipConnections.cpp is doing
There's a lot more subtlety to this but if I go into any more detail you might as well just read the code itself. It will all be in the file NetsToChipConnections.cpp, and if you're running it on a Jumperless or just an RP2040, you can set the Chip Connections and Chip Connections Alt debug flags and it will show you everything it's doing in a somewhat nicely formatted way. There are comments in the code but there are a lot of nested array things that can get pretty confusing, if you need help understanding what's going on in a particular function, let me know and I'd be happy to walk you through it.
Here's the output with the debug flags on (with some redundant bits removed because it's really long)
sorting paths by net
number of nets: 20
path[0] net: 1
path[1] net: 8
path[2] net: 9
path[3] net: 10
path[4] net: 11
path[5] net: 12
path[6] net: 13
path[7] net: 14
path[8] net: 15
path[9] net: 16
path[10] net: 17
path[11] net: 18
path[12] net: 19
number unique of nets: 26
pathIndex: 13
numberOfPaths: 13
0  [24,GND,Net 1],      1  [D4,14,Net 8],       2  [10,36,Net 9],       3  [D6,40,Net 10],
4  [D7,39,Net 11],      5  [D8,38,Net 12],      6  [D9,6,Net 13],       7  [D10,7,Net 14],
8  [D11,9,Net 15],      9  [D12,8,Net 16],      10 [D3,25,Net 17],      11 [D2,23,Net 18],
12 [D1,45,Net 19],
finding start and end chips
path[0]
nodes [24-100]
finding chips for nodes: 24-GND
node: 1
chip: D
node: 2
special function candidate chips: I J L
Path 0 type: BB to SF
Node 1: 24 Node 2: 100
Chip 1: 3 Chip 2: -1
path[1]
nodes [74-14]
finding chips for nodes: D4-14
node: 1
nano candidate chips: J K
node: 2
chip: B
Path 1 type: BB to NANO
Node 1: 14 Node 2: 74
Chip 1: 1 Chip 2: -1
... [removed for space]
path[11]
nodes [72-23]
finding chips for nodes: D2-23
node: 1
node: 2
chip: D
Path 11 type: BB to NANO
Node 1: 23 Node 2: 72
path[12]
nodes [71-45]
finding chips for nodes: D1-45
node: 1
nano chip: I
node: 2
chip: F
Path 12 type: BB to NANO
Node 1: 45 Node 2: 71
Chip 1: 5 Chip 2: 8
paths with candidates:
0,1,3,4,5,6,7,8,9,10,11,
resolving candidates
chips least to most crowded:
C: 0
G: 0
H: 0
J: 0
K: 0
L: 0
I: 1
E: 2
A: 3
B: 3
D: 3
F: 3
sf connections: I1
sf connections: J0
sf connections: K0
sf connections: L0
C: 0
G: 0
H: 0
J: 0
K: 0
L: 0
I: 1
E: 2
A: 3
B: 3
D: 3
F: 3
path[0] chip from D to chip J chosen
sf connections: I1
sf connections: J1
sf connections: K0
sf connections: L0
C: 0
G: 0
H: 0
K: 0
L: 0
I: 1
J: 1
E: 2
A: 3
B: 3
D: 3
F: 3
path[1] chip from B to chip K chosen
sf connections: I4
sf connections: J4
sf connections: K3
sf connections: L0
C: 0
G: 0
H: 0
L: 0
E: 2
A: 3
B: 3
D: 3
F: 3
K: 3
I: 4
J: 4
path[11] chip from D to chip K chosen
path[0] net: 1        24 to GND     chip[0]: D  x[0]: 7  y[0]: 2      chip[1]: J  x[1]: 15  y[1]: 3      1      1
path[1] net: 8        14 to D4     chip[0]: B  x[0]: 11  y[0]: 6      chip[1]: K  x[1]: 6  y[1]: 1      8      8
path[2] net: 9        10 to 36     chip[0]: B  x[0]: 8  y[0]: 2      chip[1]: E  x[1]: 2  y[1]: 5      9      9
path[3] net: 10        40 to D6     chip[0]: F  x[0]: 11  y[0]: 2      chip[1]: J  x[1]: 6  y[1]: 5      10      10
path[4] net: 11        39 to D7     chip[0]: F  x[0]: 10  y[0]: 1      chip[1]: I  x[1]: 7  y[1]: 5      11      11
path[5] net: 12        38 to D8     chip[0]: E  x[0]: 1  y[0]: 7      chip[1]: K  x[1]: 10  y[1]: 4      12      12
path[6] net: 13        6 to D9     chip[0]: A  x[0]: 0  y[0]: 5      chip[1]: I  x[1]: 9  y[1]: 0      13      13
path[7] net: 14        7 to D10     chip[0]: A  x[0]: 1  y[0]: 6      chip[1]: J  x[1]: 9  y[1]: 0      14      14
path[8] net: 15        9 to D11    no direct path, setting altPathNeeded flag (BBtoSF)
path[9] net: 16        8 to D12    no direct path, setting altPathNeeded flag (BBtoSF)
path[10] net: 17        25 to D3     chip[0]: D  x[0]: 6  y[0]: 3      chip[1]: I  x[1]: 3  y[1]: 3      17      17
path[11] net: 18        23 to D2     chip[0]: D  x[0]: 15  y[0]: 1      chip[1]: K  x[1]: 4  y[1]: 3      18      18
path[12] net: 19        45 to D1    no direct path, setting altPathNeeded flag (BBtoSF)
alt paths
BBtoSF    path: 8
      bb: A        sfChip: K        xMapBB: 0        yMapSF: 0        xStatus: 13
      bb: B        sfChip: K        xMapBB: -1        yMapSF: 1        xStatus: 65
      bb: C        sfChip: K        xMapBB: 4        yMapSF: 2        xStatus: -1
xMapL0c0: 4      xMapL1c0: 2      xMapL1c1: 5      xMapL0c1: 3
8     chip[0]: B  x[0]: 4  y[0]: 1      chip[1]: K  x[1]: 13  y[1]: 2      15      -1
Found Path!
BBtoSF    path: 9
      bb: A        sfChip: J        xMapBB: -1        yMapSF: 0        xStatus: 65
      bb: B        sfChip: J        xMapBB: 2        yMapSF: 1        xStatus: -1
xMapL0c0: 2      xMapL1c0: 0      xMapL1c1: 3      xMapL0c1: 1
9     chip[0]: A  x[0]: 2  y[0]: 7      chip[1]: J  x[1]: 10  y[1]: 1      16      -1
Found Path!
BBtoSF    path: 12
      bb: A        sfChip: I        xMapBB: 0        yMapSF: 0        xStatus: 13
      bb: B        sfChip: I        xMapBB: 2        yMapSF: 1        xStatus: 16
      bb: C        sfChip: I        xMapBB: 4        yMapSF: 2        xStatus: -1
      bb: C        sfChip: I        xMapBB: 4        yMapSF: 2        xStatus: 15
xMapL0c0: 4      xMapL1c0: 10      xMapL1c1: 5      xMapL0c1: 11
12     chip[0]: F  x[0]: 4  y[0]: 7      chip[1]: I  x[1]: 1  y[1]: 2      19      -1
Found Path!
resolving uncommitted hops
path    net    node1    type    chip0    x0    y0    node2    type    chip1    x1    y1    altPath    sameChp    pathType    chipL    chip2    x2    y2    x3    y3
0    1    24    0    D    7    2    GND    2    J    15    3    0    0    BB to SF    0
1    8    14    0    B    11    6    D4    1    K    6    1    0    0    BB to NANO    0
2    9    10    0    B    8    2    36    0    E    2    5    0    0    BB to BB    0
3    10    40    0    F    11    2    D6    1    J    6    5    0    0    BB to NANO    0
4    11    39    0    F    10    1    D7    1    I    7    5    0    0    BB to NANO    0
5    12    38    0    E    1    7    D8    1    K    10    4    0    0    BB to NANO    0
6    13    6    0    A    0    5    D9    1    I    9    0    0    0    BB to NANO    0
7    14    7    0    A    1    6    D10    1    J    9    0    0    0    BB to NANO    0
8    15    9    0    B    4    1    D11    1    K    13    2    0    1    BB to NANO    0     C     2     -2     13     -1
9    16    8    0    A    2    7    D12    1    J    10    1    0    1    BB to NANO    0     B     0     -2     3     -1
10    17    25    0    D    6    3    D3    1    I    3    3    0    0    BB to NANO    0
11    18    23    0    D    15    1    D2    1    K    4    3    0    0    BB to NANO    0
12    19    45    0    F    4    7    D1    1    I    1    2    0    1    BB to NANO    0     C     10     -2     4     -1
taken connections (-1 is free)
chip    0    1    2    3    4    5    6    7    8    9    10   11   12   13   14   15        0    1    2    3    4    5    6    7
A    13   14   16   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1       -1   -1   -1   -1   -1   13   14   16
B    16   -1   16   -1   15   -1   -1   -1   9    -1   -1   8    -1   -1   -1   -1       -1   15   9    -1   -1   -1   8    -1
C    -1   -1   15   -1   19   -1   -1   -1   -1   -1   19   -1   -1   -1   -1   -1       -1   -1   -1   -1   -1   -1   -1   -1
D    -1   -1   -1   -1   -1   -1   17   1    -1   -1   -1   -1   -1   -1   -1   18       -1   18   1    17   -1   -1   -1   -1
E    -1   12   9    -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1       -1   -1   -1   -1   -1   9    -1   12
F    -1   -1   -1   -1   19   -1   -1   -1   -1   -1   11   10   -1   -1   -1   -1       -1   11   10   -1   -1   -1   -1   19
G    -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1       -1   -1   -1   -1   -1   -1   -1   -1
H    -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1       -1   -1   -1   -1   -1   -1   -1   -1
I    -1   19   -1   17   -1   -1   -1   11   15   13   -1   -1   -1   -1   -1   1        13   -1   19   17   -1   11   -1   -1
J    -1   -1   18   -1   8    -1   10   -1   12   14   16   -1   -1   -1   -1   1        14   16   -1   1    -1   10   -1   -1
K    -1   -1   -1   -1   18   17   8    -1   10   11   12   13   14   15   16   -1       -1   8    15   18   12   -1   -1   -1
L    -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   -1   1        -1   -1   -1   -1   -1   -1   -1   -1
8    same chips: @, @, @, @,     @, @, C, C,
9    same chips: @, @, @, @,     @, @, B, B,
12    same chips: @, @, @, @,     @, @, C, C,
final paths
8    15    9    0    B    4    1    D11    1    K    13    2    0    1    BB to NANO    0     C     2     0     13     0
9    16    8    0    A    2    7    D12    1    J    10    1    0    1    BB to NANO    0     B     0     0     3     0
12    19    45    0    F    4    7    D1    1    I    1    2    0    1    BB to NANO    0     C     10     1     4     1
To be continued with Driving the CH446Qs
