Let's give it another try
A project log for Integrated Circuit decapping without acid
IC are amazing, but always closed in eopch which seems impossible to remove. Here we propose a method to decap without acids
100dollarhacker100dollarhacker 11/01/2023 at 21:070 Comments
I suspect that last time the problem was shielding that was too close. So this time, I used a box wide enough to not create capacitor between shielding and components.
Placed went to cool it down
Made EM shielding using aluminum foil. Placed cone to concentrate air flow. And used more heat resistant Tesla coil
To speed up the process I've filed the IC package where I thought silicon should be (usually in the middle of the package)
Now for the fun part... PLASMA!!! That's a good place to warn everyone that you should NOT touch plasma with your hands or conducting material. Use ONLY shielded tools
It still manual (I am testing some ideas how to make it automatic)
And the result:
In the middle you can see silicon. Now let's look on it under the microscope
This time I got lots of residue left. I've tried to use more plasma but eventually silicon popped out and I was unable to find it. I guess I should use ultrasound bath next time.
Here is another happily extracted silicon
