Prep work
A project log for Frequency counter becomes Nixie clock
Turning an old device with Nixie tubes into a clock
walterWalter 08/12/2023 at 12:030 Comments
I've ordered some wires to connect to the nixies. They haven't arrived yet. I did some final prepwork.
I put some screws on the nixie PCB and glued it to the existing main board using a two component adhesive.
The other thing I did is replaced the resistor on the tube anode on the six nixie PCBs with a wire bridge. I also cut the traces from the kathodes so the tubes are no longer connected to components that are remaining on the main PCB.
