Back to the Lathe…
A project log for Woody the Electric Four Passenger Bicycle
Woody is a scratch built quad wheel bicycle with four passenger capacity, with electric power to assist pedaling.
john-guyJohn Guy 08/29/2023 at 03:550 Comments
So, on to the bottom brackets. Start with a piece of 1.75” OD tubing, and cut off two pieces a bit proud of 68mm. Squared the ends, cut bearing seats, and gave the edges a bit of sanding. Repeat for second. These use bmx bottom brackets.
Added to the BB are two plates from sendcutsend.com . These needed just a quick touch with a 1.5” drum sander in a cordless drill and voila!
These allow 0.6” of fore and aft adjustment for chain tensioning. They clamp to a TBD place on the frame per below.
