I broke my 3D printer.
The final revision of one of the mounts came unstuck and became a giant evil glob on the hotend, and when I removed it I severed all the wires to the thermocouple and heater!
I do have my first drafts, however.
Heres a pic of the test fit with the bracket system.
TThe intention is to use adhesive to bond the printed parts to the case, then use heat set inserts and screws to mount the hardware to the brackets.
This will keep everything in place and still allow me to get in and remove or replace things if that's needed.
The photos show off the stack of boards one at a time so you can see the way it all fits together.
I will try to modify the existing prints by hand somehow to work.
