The cabinet
A project log for VSTiPiano
A versatile stage piano with integrated VST plugin compatibility, offering advanced control and dynamic performance capabilities.
jan-bertJan Bert 09/12/2023 at 19:170 Comments
After creating a preliminary 3D CAD sketch, I measured the precise dimensions of the cabinet by positioning the keybed and mini-ITX on the bottom plate.
The cabinet is constructed from plywood, coated with two layers of Warnex, a material commonly used for subwoofer cabinets. This method has proven to be much simpler than applying Tolex, which is often used for guitar amps.
The side panels feature a slot for easy access to the aftertouch strip. American walnut side panels are then securely attached to the multiplex side panels to give it a polished finish.
