Adding the optocouplers
A project log for Custom Intellivision Controller
There have been many redesigns of the Intellivision controller. This is mine.
deftcoyotedeftcoyote 01/02/2024 at 22:560 Comments
Optocouplers wired for the 2nd controller. I'm having a bit of trouble with getting different outputs. Since they're all grounded to the same outputs, I think some of the pins are being affected by the others. I haven't had time to really investigate.
I also started on the kicad schematic for the controller board. I'll have a 5-pin ribbon connecting to it with the arduino leads, power, and ground.
