Wall-U
creating a Wall-e but not like the other girl
movie props : Wall-E, starting by making it in cardboard and see where it leads us.
Creating an interactive Wall-E like robots that can move around while detecting when there is a wall in front of it. Wall-U should be able to move its arm and eyebrows in a first time.
Then might add shock sensor to make it cry if you kick it .
What we need so far :
  • [ ] 2 DC gear Motors + L298N (wheels)
  • [ ] 2 servos 180 (2 arms)
  • [ ] ultrasound sensor
  • [ ] breadboard
  • [ ] arduino uno
  • [ ] power bank/cell/thing battery ( battery for motor AND arduino )
  • [ ] switch button
  • [ ] acceleromater
Wall-U V1 :
  • wheels
  • arms moving
  • wood box
  • detects walls and avoid them
  • open its trap manually
  • raise its arm when kicked or shakes
Wall-U V2 :
-eye moving
- cry when kicked
- make sounds
Wall-UV? :
  • belly opening automatically
  • head moving
  • make it pretty
  • telecommande
  • makes noises
  • painted
Portable Network Graphics (PNG) - 103.10 kB - 03/14/2024 at 10:42
Preview
Download
Standard Tesselated Geometry - 5.94 kB - 01/12/2024 at 15:23
Download
Standard Tesselated Geometry - 8.68 kB - 01/12/2024 at 15:22
Download
Standard Tesselated Geometry - 11.41 kB - 01/12/2024 at 15:22
Download
Standard Tesselated Geometry - 1.45 kB - 01/12/2024 at 15:22
Download
View all 28 files
  • 1 × L298N Interface and IO ICs / Peripheral Drivers and Actuators
  • 2 × DG02S48:1 Mini DC gear box
  • 1 × Arduino UNO
  • 1 × 7.5V battery
  • 2 × 180 servo motor M995FR
View all 8 components
  • Sound electronics
    mariz924 days ago 0 comments
    We received the electronic part for the sound device and are trying to make the code work
    we re made the box 20% smaller and laser cut it.
    02/05/2024
  • The electronic part working !
    mariz9204/11/2024 at 09:17 0 comments
    Today we wired every electronic again with the new wheels and everythign works again !
    we don’t have the new box yet though ….
    04/04/2024
  • Neat wiring & gyro code working !!
    mariz9203/14/2024 at 11:22 0 comments
    Today we finished to modelise the wiring on EASYEDA and finally made the code for the gyro work as we wanted !
  • Merging code and parts
    mariz9201/12/2024 at 11:05 0 comments
    Today we merged the code of each part toguther and also the physical part !
    We started by putting the caterpillar tracks on the chassis and tested it with the motors.
    We tried to make the wire cleaner
    Biggest challenge was putting the arm in the box.
    we finished improved the code.
    AVENGERS ASSEMBLE DAY
    it starts looking like something
  • caterpillar tracks
    mariz9201/12/2024 at 09:09 0 comments
    Today we went to Leroy merlin To bug more screws !
    We finally assembled our caterpillar tracks.
    11/01/24
  • starting to look like something !
    mariz9201/12/2024 at 09:08 0 comments
    Today we assembled the caterpillar ( they got bigger uhu) but we couldn’t finish to put them toguether because we didn’t have enough screws.
    We put the wheels on the motor and made them work with the box.
    And the arms we assembled as whole !
    21/12/23
  • Caterpillar tracks and moving arms
    mariz9201/12/2024 at 09:04 0 comments
    Today we assemble our firsts parts of caterpillar tracks and part of the wheels!
    We also made the little trap door for the box and put the head on the top of it ( the proportion are off but let’s say it’s cute !)
    We also have the mechanism of the arms working !
    14/12/23
  • Box !!
    mariz9201/12/2024 at 08:58 0 comments
    Today we used the laser cutter to make the wall-U box !
  • arms !
    mariz9201/12/2024 at 08:56 0 comments
    We printed the first parts of the arm !
    07/12/23
View all 13 project logs
  • 1
    3D models
    • 3D print the caterpillar tracks : we printed 40 pieces in total (20 for each side), 2 main wheels for the motors and 4 secondary wheels. We assembled the tracks using M4x25 screws and bolts.
    • 3D print the arms and the mechanism that go with them. You will need one of each piece. ( more detail in the PDF concerning the arms in the files)
    • 3D print the head and eyes. Place the ultrasonic sensor in the space and add the eyes.
    • You can find the models in STL in the file.
  • 2
    The box :
    • 20X20X25 (inside)
      Chassis : 3.5 cm high 20cm large fold plastic and screw on the bottom
    • Laser cut the body and assemble it. It should click into place thanks to the finger joints. Our wood wasn't perfectly flat so we had to use a few pieces of tape to keep everything together. We also put the SVG (laser cuttable) file to your disposal.
  • 3
    The code
    • Upload the code into an Arduino board (we used a Uno). Plug in the components. To plus everything, you can follow the image of the wiring we posted.
View all 4 instructions
