In principle, this robot can be compared to a 2D plotter. Based on a coordinate system, a magnet underneath the table top is moved on two axes. The magnet causes the ball placed in the sand to roll around as if by magic. The ball leaves behind arbitrary patterns and line drawings without the technology being in the foreground.
The drawing templates can be transferred to the table in the form of GCODE via WiFi. The salon table is equipped with stylish RGB LEDs to make the contours of the drawing appear in all possible colors and create a stylish ambience in the living room.
The lighting is based on RGB LED strips embedded in profiles. The table is finally covered with a bespoke glass top to maintain the function of a salon table and give a high quality appearance.
Want to see this table in action? Check out my Youtube Channel
Hi... If you need some help with the documentation, or need it translated into spanish.... It will be a pleasure!!!
