sensor carrier release v1.0, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)
Standard Tesselated Geometry -
112.58 kB -
10/29/2023 at 12:34
sensor carrier prototype v0.2, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)
112.58 kB -
10/29/2023 at 10:26
* Removed the 3 poles of the holes in the back that accommodate the pins of the more common version
* Adjusted the hole for the TCRT5000 head
* Moved the words to the bottom of the part
* Added a hole and a space for a nut to properly mount the sensor in the carrier
The carrier uses a M2x6 bolt and nut to secure the sensor inside. A washer can be made from cutting off a 1mm section of PTFE tubing. I stacked a normal metal washer on top, so the screw head doesn't just go through the PTFE washer.
I made a v1.0 after some more adjustments of the TCRT5000 head hole
