Design phase
A project log for Lunar PICO rover
A PICO sized lunar rover
apollo-timbersApollo Timbers 02/07/2024 at 02:310 Comments
Currently finishing out the design phase of the robot, along with acquiring/building all of the parts.
Done-
  1. Tested PICO board controlling a motor and a servo
  2. Printed main chassis and it failed
  3. Redesigned main chassis
  4. Added LoRa COM module and found batteries that would fit
  5. Sent a wheel off to get printed in MJF Nylon PA12 (MJF)
  6. Have most parts, waiting on servos and a few others
Need to do:
  1. Print main chassis and cover
  2. Print wheel arms
  3. Test wheel when back make changes if needed
  4. Order more wheels, need 4 :)
  5. Wire up camera
  6. Program some "get it working code"
  7. Add arms and micro gear motors
  8. Test servos with arms
  9. Add wheels and do a bunch of tests.
  10. Buy simulated moon regolith?
  11. Redesign and make robust for education version
