Failure failure failure
A project log for Modular Pi Cam
A Raspberry Pi based camera that can swap body parts and camera modules
jacob-david-c-cunninghamJacob David C Cunningham 02/29/2024 at 01:210 Comments
Oh man... I hit submit... it's all gone. Great...
Anyway I failed setting up bluetooth react native app... I think it's because BLE vs. native bluetooth.
Bluetooth is also not easy it turns out.
So I went with door #2... Access Point.
Anyway I did order the camera module v3 wide version, that suits me since I'm more of a landscape person.
The idea would be... if you put the camera on a tripod it can be controlled with a web interface (viewed on your phone or other wifi device).
I just prototyped out the code based on the mjpeg_server.py example
It all works... I just gotta figure out all the values I can change, what makes sense to change.
Also I'm trying to come up with a name for the pi camera software for handhelds.
I'm not really the guy to start a repo to be followed (poor code practices) but it's getting to that point where I went a dynamic/adaptable software per hardware.
