Time to order the hardware
A project log for MQTT hack for OpenSprinkler OSPi
At the beginning of 2024 the opensprinkler firmware cannot (yet) subscribe to MQTT topics. Can I make a hack to solve this?
mabe42MaBe42 03/03/2024 at 15:170 Comments
Since I now can provide moisture sensor values via MQTT to OSPi, it's time to order a board and the other necessary hardware.
As I understand, there are plans to integrate MQTT subscriptions into the OpenSprinkler firmware. I hope that this will happen in the not so far future. Until then I will use my workaround/hack.
