Wooden Vertical Carousel Spice Rack Alchemy Design
This project features a making of Wooden Vertical Carousel Spice Rack adorned with Alchemic Design decorations
This project features a making of Wooden Vertical Carousel Spice Rack adorned with Alchemic Design decorations, alongside spice boxes embellished with laser-engraved patterns.
Using Oak, Alder, and Walnut, I created a smaller version of the Vertical Carousel I've long envisioned.
Along the way, I delved into the intricacies of wooden mechanisms, mastering gears, chains, and transmissions.
All challenges have been tackled, and the project is now available as open source.
Join me in bringing this elegant and practical creation to life.
License: CC BY-NC 4.0 Deed Creative Commons - Attribution - Non-Commercial license https://creativecommons.org/licenses/by-nc/4.0/
Materials and tools used in this project:
- Oak sliced veneer 4.5mm, 2,5 mm
- Alder sliced veneer 4.5 mm
- Walnut sliced veneer 4.5mm, 2,5 mm
- Plywood 4 mm, 6 mm
- Bearings: d=4, D=9, H=4 x 8 pcs
- Bearings: d=8, D=14, H=4 x 10 pcs
- Screws: 2.5x12 mm, 2x10 mm, 2x4 mm.
- Glass bottles: D=47, H=80, V=90 ml - Small metal brush
- Bamboo sticks D=4mm (for BBQ)
- Magnets D=3mm, H=4mm (NdFeB) - Masking tape
- Glue: Titebond 2, 3M Scotch-Weld Fastbond 30, CA Glue + Activator
- Wood tinting: Vidaron Beica Walnut (B09), Palisander (B10), Mahon (B13)
- Oil: Tundra oil with Carnauba Wax
- Bee Wax
- DIY Laser cutter/engraver 520x520mm, 5.5w
- Disk sander - Screwdriver
- Hand router 1600 W, V-bit 45 degree, Round bit R=5 mm
- Sandpaper 120, 220, 320 - Clamps
AutoCAD DXF - 419.72 kB - 03/24/2024 at 13:51
Download
AutoCAD DXF - 318.92 kB - 03/24/2024 at 13:51
Download
AutoCAD DXF - 294.24 kB - 03/24/2024 at 13:51
Download
AutoCAD DXF - 57.94 kB - 03/24/2024 at 13:51
Download
AutoCAD DXF - 92.92 kB - 03/24/2024 at 13:50
Download
View all 11 files
  • 1
    Step 1
View all instructions
