Fork for people with no fingers
We have created a fork for people with no fingers
In a team of 3 we have created a fork for people with no fingers, after having received instructions and requests from a fingerless person
When we choosed to work on a fork prothesis, we begun by working on two types of prototypes. In one hand we worked on an "horizontal" prothesis (in the same position as the daggers of assasins creed) in the other hand a "vertical" prothesis ( perpendicular to the palm of the end). And as you will see in the next notes we choosed the "vertical" one.
  • 30/04/24
    killian.courson6 hours ago 0 comments
    Today we were able to test our prototype with a fake hand of the kid and discovered that the handle was to short and so we decided to modify it. We also decided to find ideas for an universal mould.
    And we finally round all the edges to make it confortable and safer.
  • "Horizontal" prothesis
    killian.courson03/26/2024 at 16:40 0 comments
     This is the last prototype of the "horizontal" prothesis, we choosed to stop to work on this because it's too big and uncomfortable for the user.
  • Prototype and issues to be solved
    Shrey Mody03/26/2024 at 16:28 0 comments
    It is the first real prototype for a vertical prothesis, our problems are that it is not stable and the casing is only made for one particular fork.
    In the future, we want to solve these problems: Casing made for all types of forks and a system so that the fork is stable and doesn't fall, our current ideas for the stability issue is a lid for the fork.
View all 3 project logs
