ARACNA Concept
Open Source Robotics Platform for Evolutionary Algorithm Development
Updating the aracna-hardware for FDM printing, and making the design more accessible to build.
orgin: https://github.com/CreativeMachinesLab/aracna
Hardware:
  • 8x DS5180 SSG Digital servo (80kg)
  • 8x DS servo disk (8 threaded holes)
  • 24x 8x5x2.5 bearing (MR85ZZ)
  • 5mm 304 stainless steel shaft
    • 4 x 3 custom length cuts
  • 28x M3 self tapping screws (15mm)
  • 16x M2 self tapping screws (12mm)
  • 16x M4 hex bolts (20mm) + 16 x nut
Filament:
  • PETG (tested)
  • print settings (Voron standard)
Assembly level (challenging)
Standard Tesselated Geometry - 26.25 kB - 04/28/2024 at 00:32
Download
Standard Tesselated Geometry - 25.47 kB - 04/28/2024 at 00:32
Download
Standard Tesselated Geometry - 123.91 kB - 04/28/2024 at 00:32
Download
Standard Tesselated Geometry - 201.25 kB - 04/28/2024 at 00:31
Download
Standard Tesselated Geometry - 201.55 kB - 04/28/2024 at 00:31
Download
View all 16 files
  • Changelog
    TechSpiderbot04/28/2024 at 00:45 0 comments
    Changelog V0x
    Version V02:
    • Updated design scaled up some parts.
    • Released STL's (Untested)
    Version V01:
    • Updated hardware design for FDM printing.
    • Added press fit joints.
    • First leg 3D Printed and assembled
View project log
TechSpiderbot wrote 04/11/2024 at 18:46 point
Interesting indeed, original designs is only printable with a (DOD) 3D Printer cause of the 0.2mm used tolerances
Jacob David C Cunningham wrote 04/10/2024 at 00:33 point
interesting design, very compact
TechSpiderbot wrote 05/08/2024 at 05:47 point
STL's are available
