Features:
- RJ45 connectors for fast and stable connection.
- Plug and play system.
- Configurable to acquire 5/24V PNP and NPN inputs.
- 5/24V selection for outputs.
- Each input or output connector also carries the 5/24V POE-style power supply.
Protections:
- Reverse polarity protection.
- Self-resetting fuses for each power supply.
Outputs:
- Full 5 Axis Step/Dir/Enable control outputs.
- 24-5V Outputs – Spindle, Mist Coolant, Flood Coolant, Dust Extraction.
- 3 x 24-5V Auxiliary outputs controlled by additional M-codes.
- 0-10V or 5V PWM outputs for Spindle VFD and laser module.
- CW/CCW/security enable for spindle VFD.
Inputs:
- 5x Closed Loop Stepper Motor/Servo Alarm Inputs.
- Opto-isolated inputs for DOOR/PROBE/HOLD/START/E-STOP input signals.
- Opto-isolated inputs for all limit switch input signals (Mechanical and Inductive limit switch compatible).
- 4x Opto-Isolated auxiliary inputs.
- An independent input for override vac output.
Firmware/Software Compatibility:
Connectivity:
- USB.
- Ethernet.
- SD Card.
- Auxiliary USB.
- I2c connectivity for external plug-in communications.
Example Driver Adapter expansion
Relay module for split 4 Neuron-1's outputs in protected outputs with fuses
![](https://cdn.hackaday.io/images/7015751718048207644.jpg)
5/24V PNP/NPN compatible inputs
![Input example Input example](https://cdn.hackaday.io/images/2528481718048207764.jpg)
