Projct Status
A project log for thingSoC Grovey ADC
The thingSoC Grovey ADC provides four (4) Analog-to-Digital channels of 16/12 bit resolution for the Grove System
pattern-agentsPattern Agents 02/10/2017 at 05:060 Comments
Revision 1.0 : 1/1/2017 Tested and Working Correctly.
Notes: Since the maximum sampling frequency of the ADS1115 is 860Hz, the input anti-aliasing filter is set for 860Hz/2 or around 430Hz. Most ADS1115 breakout boards DON'T include any input conditioning or filtering, but we include in a simple single pole, low pass filter on the four (4) Grove input Jacks.
