Building Android, by the book: Setup the Build Environment
A project log for Breaking Androidâ„¢
Building and breaking the Android AOSP on the BBB. Android is a trademark of Google Inc.
jlbrian7jlbrian7 03/11/2017 at 14:440 Comments
References :
https://source.android.com/source/initializing.html
For Ubuntu >= 15.04 (you need a 64bit version of ubuntu. The website says it recommends 14.04, I am using 16.04. )
sudo apt-get update
sudo apt-get install openjdk-8-jdk
sudo apt-get install git-core gnupg flex bison gperf build-essential \
zip curl zlib1g
-dev gcc-multilib g++-multilib libc6-dev-i386 \
lib32ncurses5
-dev x11proto-core-dev libx11-dev lib32z-dev ccache \
libgl1
-mesa-dev libxml2-utils xsltproc unzip
Configure USB Access. Replace <username> with your username
wget -S -O - http://source.android.com/source/51-android.rules | sed "s/<username>/$USER/" | sudo tee >/dev/null /etc/udev/rules.d/51-android.rules; sudo udevadm control --reload-rules
