The tube fiddler
Extensible tube bench test power supply and measurement unit
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This power supply and measurement unit will be designed for testing tubes and tube arangements, usually basic amplifier designs, etc... with a powerfull power supply and versatile regulator.
Base design will include a power transformer and switch mode regulator in order to produce a great range of supply voltages with stability in mind, and implement computer controlled features like current limiting, curve tracing, etc...
