The upcoming version of Terminal-BASIC uses SPIFFS to implement NVRAM and file system commands on esp8266:
- SAVE
- LOAD
- CHAIN
- DSAVE
- DLOAD
- DCHAIN
- DIRECTORY
- SCRATCH
- HEADER
I'v test it on ESPBoy device. There is no suuport of TFT screen, buttons, sound and LED for now, but the port is fully functional, using UART.
![](https://cdn.hackaday.io/images/8829141583878417260.jpg)
![](https://cdn.hackaday.io/images/2622171583878462591.jpg)
Sketch with data folder for SPIFFS, containing some BASIC programs: terminal-basic-2.3-a1
DIRECTORY command shows the files list. Unfortunately, the files, written using esp8266 SPIFFS uploader have names, starting with '/'. To start AMAZING maaze generator, for example, one needs to type the command DLOAD "/AMAZIN"
without BAS file extension
