Become a member to follow this project and don't miss any updates
Arduino Game Console - the BlueOkiris Gameduino
An arduino uno based game console.
0 5 6
Share on twitter   Share on Facebook
This project was created on 08/01/2014 and last updated 2 months ago.
Description
First of all, this is NOT using the gameduino shield. I did not know that was a thing when I built this. This is simply an arduino uno, a makeshift button from duct tape, a breadboard, some wires, and aluminum foil, an analog stick, a seeedstudio tft touchscreen version 2, and lots and lots of time in software.
It's software is a bit slow, but it works, and it loads multiple games from different SD cards. So far there are two, one that uses the touchscreen - a form of Guess the Number, and one that shows off the button use - the classic, Pong.
Here is a video at:
https://www.youtube.com/watch?v=wNBl15fcvTI&list=UU5KExpfYQgvgg52HC1xyemw
In the description there is a link to my website with the main code, the code for the two games, and information on how to make games. If you enjoy it, you can try to make it yourself, and make games for it yourself.
I am currently working on improving speed and am going to make an RPG. This is my first project, and I hope you like it.
Details
If you like this project and wanted to make a game, I would love to see and would probably make a video of me playing it. You can send me it at dylantdmt@gmail.com
Components
  • 1 × SeeedStudio TFT LCD Touchscreen V2 A tft touchscreen with its own library and a micro sd card slot.
  • 2 × Micro SD Card A storage device used in my project to hold the games
  • 1 × Arduino Uno A small microcontroller used for a number of things
  • 1 × Makeshift button A pushbutton, but created by me
  • 1 × Analog Stick An analog device that can move in 360 directions and gives me up, down, left, and right
  • 1 × Stylus A stick with a round end
Project logs
  • Almost Done - Version 2.0
    2 months ago • 0 comments
    I have finished Version 2.0 of the BlueOkiris Gameduino and updated Pong and Guess the Number. However, I will not be releasing the update until I have a new game. I have started working on Xorx, an RPG for the console, but that will not be complete for a while. If anyone wants to create a game for the console, you can find information at http://blueokiris.webs.com/gameduino/
    Then you can email me at dylantdmt@gmail.com with your game attached.
    I will place it in the next video showing version 2, and I will post it on the website unless otherwise intended.
  • Paint
    2 months ago • 1 comment
    Added a small paint program. It boots when you leave out your SD card. Again, will post as Version 2 as soon as I make the RPG.
  • Speed and Color
    I just improved the speed so that it has less flickering. Now all colors must be entered in a RGB565 manor, but it does allow for more colors. I will post an updated video and code under Version 2 as soon as I make the next game, my RPG.
View all 3 project logs
Build instructions
  • 1
    Get supplies, listed above.
  • 2
    Take your button or real pushbutton, and set up a circuit. Do not use a male end to connect to an arduino. Fit the open wires into the slots. Digital pin 9.
  • 3
    Take the analog stick and solder the appropriate wires to it. Place ground to ground, 5v to 5v, x to A4, and y to A5. Again do not use male ends to the arduino.
See all instructions
