2.0 Version
A project log for Rocket Pistol
I have an idea for a rocket pistol, Estes rockets and a 9V battery. Laser sights for ultimate accuracy
j0z0r-pwn4tr0nj0z0r pwn4tr0n 12/07/2015 at 05:310 Comments
I bought a different spray can handle and refitted it with the hardware. The epoxy is drying on it now:
I also need to make a cheap rocket because most of the Estes rockets are too big to properly fit on the guide rod.
I have a design going with an old plastic cigar tube that should be fine. It has an "A" sized motor, the smallest you can get (for safety). If all goes well, I should be doing a test launch next weekend!!!
