11Test your board(s)
Make sure your boards work! A simple bitstream that sequentially asserts each of the pins will help to ensure they are functioning correctly. Attach LEDs to the pins and watch that each LED lights up by itself and all of the pins light up at the correct times. LEDs that don't light up mean there is a broken connection, multiple LEDs lighting up means there is a short.
The TinyFPGAs sold by me on Tindie are all tested using an automated test rig.
